c8n
- Mar 4, 2013
- 819
If you are having issues getting good results from a rinse less wash, either your technique is off or the vehicle is just too dirty. Having done hundreds close to thousands of them I can tell you that when your technique gets top notch your results will blow away 2bm and will save you tons of time, effort, and product.
Sent from my DROID RAZR using AG Online
Provided you use all the correct techniques for both methods, the question becomes, which is safer? I tend to think it would be the traditional wash unless someone tells me that the rinseless will melt away the dirt and grim on contact. With a good foam and a rinse, you are pretty much knocking out much of what can cause the scratches off your paint before you even touch it.
Dont get me wrong, rinseless does provide the lubrication to minimize scratching to a certain point, but i still think the traditional wash with foam and rinse is safer.
