Thanks, Bob!
So, in the case of removing brown from tires, ARO will have a big edge compared to P21S TAW(based on both pH's), correct?
Do you happen to know the pH of DP Cleanse-All?
Happy New Year!!!
rops:
Mark...
Sometimes: Having a big edge... one cleaning product may have over another cleaning product shouldn't always be based on just the overall ph value of the products, but should include the "cleaning ingredients" ph values, along with the other ingredients (chemicals) that go into formulating each product. Having a big edge, in this respect, may not equate to a better or safer product.
But why start off with a product whose ph value is on either the high-end or low-end of the ph scale, IMO. The base, or acid, used for the cleaning role in some products, and their corresponding ph values, does play an important role in determining the overall products' ph value/diluting ability.
I personally don't have a problem in choosing cleaning products that are ph balanced/controlled from the get-go.
Remember some acids when diluted will not always make them less acidic....Same with some bases. And then again, it depends on the diluting substances that might be added.
Here's a chart of some acids and bases and their ph values
ACIDS:
Compound Name-
Formula-
pH
hydrochloric acid- HCl- 1.1
sulfuric acid- H2SO4- 1.2
sodium bisulfate- NaHSO4- 1.4
sulfurous acid- H2SO3- 1.5
phosphoric acid- H3PO4- 1.5
hydrofluoric acid- HF- 2.1
acetic acid- HC2H3O2- 2.9
carbonic acid- H2CO3- 2.8
hydrogen sulfide- H2S- 4.1
sodium dihydrogen- NaH2PO4- 4.4
phosphate
ammonium chloride- NH4Cl- 4.6
hydrocyanic acid- HCN- 5.1
sodium sulfate- NaSO4- 6.1
sodium chloride- NaCl- 6.4
Water-H2O-7.0 (neutral)
BASES:
Compound Name-
Formula-
pH
sodium acetate- NaC2H3O2- 8.4
sodium bicarbonate- NaHCO3- 8.4
sodium biphosphate- Na2HPO4- 9.3
sodium sulfite- NaSO3- 9.8
sodium cyanide- NaCN- 11.0
ammonia- NH3- 11.1
sodium carbonate- NaCO3- 11.6
sodium phosphate- Na3PO4- 12.0
sodium hydroxide- NaOH- 13.0
I wonder which of the above bases (alkalines) ARO and P21S products have in them? The ph range indicates they would be between sodium chloride (a salt) and sodium hydroxide (lye).
As far as the ph of DP CleanseAll...That info should be listed on the product's MSDS. Or, perhaps an inquiring call to one of the AG reps. may be fruitful.
Again..I hope this helps a little.
