Klasse Act
- Feb 21, 2012
- 27,842
- 2,961
I'm sure it's done already as I post this
It's the engine I'm most looking forward to. My current S550 has the gen-2 Coyote, so I basically skipped the gen-3 upgrades which brought more hp and a higher rev limit. So instead of 410 hp and 6,400 rpm to play with, I'm looking forward to 470 hp and a 7,500 rpm limit. I'm all about induction note, so the updates all right up my alley.
I can't believe the negativity toward the S650 from the wider Mustang community, so much cattiness and defensiveness over a car that some aren't even going to buy. Is it just sour grapes for those who bought a late S550 and now have the old model? I get it, the styling is divisive, and the car is not as all-new as perhaps people were expecting. But when has a Mustang been truly all-new? S550 was probably the biggest step forward in a long time, setting the bar much higher. In this climate of electric car expansion and all the development dollars that is soaking up, we as a car community should be thankful for the likes of Ford, Nissan and Toyota even bothering to invest any money into dedicated sports cars/coupes.
I hate excessively lowered cars, just looks stupid in my opinion.
I couldn't agree with you more about lowered cars just to be low, looks stupid and not practical️
Hey I feel attacked all of a sudden!
No i get it. We like what we like. I personally can’t stand a car at stock height and factory wheels. Wheel well gap makes me wanna
. I want mine to stand out in a crowd of other same cars. But that is just me. Shoes for my persons and cars has always been a priority.
I will say this, LOVE that OEM wheel, is it available in silver
Used Optimum Instant Detailer & Gloss Enhancer for the first time today.
From what I can gather, Optimum and Opti-Coat ceramic coatings tend to lack slickness, so using this product helps remedy that. Like all quick detailers, I really like how easy this is to use, able to be applied across all surfaces as a drying aid or final step after washing. Another sleeper product by Optimum.
Finally, the replacement dust shields arrived at the dealer today.
What do think, should I ceramic coat these too?
Really? I think that looks gorgeous. Different folks and strokes and all..
Early on when the S650 was announced it was suppose to be an all new platform, motor.
I think that changed when switching to investing in EV’s. The sell enough to continue producing but not enough to develop a whole new car
I’m not sold on the looks but waiting to see in real life.
I’ve seen silver and bronze. Personally I feel about silver as you do about gloss black. For me to plain.
If I do one I’m thinking red or white with the bronze
Edit: saw DFB post these. Get the Bronze package…. We could maybe be twinsies
Hey I feel attacked all of a sudden!DFB's GarageDFB's GarageDFB's GarageDFB's Garage
Yeah but your bagged, different deal hereSent from my iPhone using Tapatalk
Two things come to mind -
- First, a blocked exhaust port or spark arrestor in the muffler. This is mostly applicable to 2-stroke engines, but it you don't run the machine at full or high revs often, the carbon doesn't burn off properly and eventually causes it to build up and block, ultimately preventing the engine from exhaling.
I haven't pulled down a small GX25 / GX35 Honda before, but you would need to inspect the small muffler outlet screen, which your unit may or may not have as there are a few different designs for these engines. Remove any built-up carbon with a wire brush or by heating it with a flame and again agitating with a brush.
For the exhaust port, you will need to remove the muffler and inspect the port for carbon build up. Remove by gently scraping the carbon away. In both cases, you will need to remove the engine shrouding. While the muffler is removed, make sure the inlet is not blocked either.
- Secondly, it could be that engine is not getting enough fuel at full throttle. In which case, check the fuel filter in the tank. Otherwise, you will likely need to rebuild or replace the carb. These are a diaphragm carb, which become hard with age and don't pump fuel properly. Usually, you will have starting issues as well. On my GX25 powered Atom Edger, I had the carb rebuilt and fuel line replaced to solve this issue.
Issue solved - finally.
Once I replaced the carburetor, the GX25 now works like charm.
I can go full throttle, without chocking or loss of power.
:xyxthumbs:
Excellent!
Secondly, you need to check and replace the oil. That tends to catch a lot of people out accustomed to two-stroke small engines that never require that sort of maintenance. This is what happens when a GX35 runs low on oil.......................
I remember back in the 90s I used to take my car to a workshop that also serviced the local HWP cars, both Fords and Holdens, and the owner always told me that cop cars didn't always need to be faster, but they definitely had to have better brakes. That was how they caught most people, first they'd run out of brakes, then they'd run out of talent. If they were available, I always fitted the police spec pads to my Commodores, they were the same backing plate, but they had a larger area of pad material, I even fitted them to my Cross 8 after some disc warping issues.
