So what I'm hearing is the green CSS polishing pad is recommended for the AIO?\
Asking as someone who will do a one step on the wife's car, not as a pro getting paid for his services.
i 100% agree Mike, when i first started out a was a dollar chaser and id go after every penny i could, and i destroyed my body and my wallet barely grew from the after math.
no i fully understand and have no issues with the power of saying NO or turning away a job, even high paying jobs if i dont get a good feeling about the customer after talking with them about a potental job.
i think thats definaelty a lesson those looking to make this a businesses need to learn and accept in teh early stages for sure.
Good read all the way throughout!
When I do an AIO job it is usually the 3401, Speed (now using BF One Step as my new Favorite) and the white LC Force Hybrid pads.
(Love these pads but the white ones certainly hold water when cleaning differently than any other pad I have used. Kinda neat)
Yes, the white Force Hybrid hold water, I think that's the "hybrid" part of this specific pad. The foam structure is part open cell and part closed cell. Closed cell pads hold liquids inside of them.
See my article here,
Open Cell Foam or Closed Cell Foam? - A simple test you can do to determine by blowing air into the pad
It’s a pretty fool proof system for just about all paint types IME.
I agree. When I detail for money I tend to use the BEAST as I find the 8mm gear-driven rotation and oscillation enables me to correct, polish and seal paint as fast as humanly possible without making mistakes and while maintaining top quality.
Sometimes I show other tools in a write-up and when I do this it's catering to other people's budgets or preferences, Here's and example where I showed how to do one-step high quality production detailing to an old 2-door Chevy using the Griot's Garage 6" Random Orbital Polisher. I could have done it a LOT faster with the FLEX 3401 but I wanted to show a tool that the average person could afford that wasn't junk but also didn't cost $400.00+ dollars just for the tool. A person reading the below thread if they are NEW to machine polishing besides having to purchase the tool will also have to purchase pads, products and towels and the more pads the better for them and their time-efficiely as well as overall results.
Review: BLACKFIRE One-Step Cleaner/Wax by Mike Phillips
Note the tool and also note I show how many pads I used....
I count 8 pads. Down a ways in the thread I also show how many towels I used. When I take pictures like this it's to telegraph a message to people that it takes more than one pad to buff out a car and it takes more than one or two towels to wipe off product.
I have learned thru the years that changing pads often will lead to much longer pad life in the long run. I have no problem using 10+ pads a vehicle. My cut rate never slows as the pad becomes wet and soggy with product if changed often.
Yeperdoo...
More pads are better!
:xyxthumbs:
I too use LC orange foam cutting pads with one-step cleaner/waxes and sometimes you can get away with it but you won't know unless you inspect and if you really want to see what's going on at the surface level then chemically strip the paint and inspect with a SCANGRIP Sunmatch Swirl Finder Light or some other strong swirl finder light.
Also - When a foam "cutting" pad is clean and DRY it is its sharpest and this is when it is more likely to cut the paint and haze it. As you work around the car with the same pad the pad will become soggy or wet or saturated with product and the foam will become softer and broke-in. At this point you're probably using a pad closer to a "polishing" pad and no longer a "cutting" pad.
This is also where some seasoned detailers and also newbies get lucky because they don't have a lot of pads so they can switch out to a fresh DRY foam cutting pad for each panel. The lack of pads keeps them safe and they may read what I've written and think I don't know what I'm talking about. But I have the pad resources to switch over to a DRY foam "cutting" pad for each panel and I'm telling everyone, there is such a thing as pad haze and it can and will bit you in the behind some day.
This is an excellent read, but my apologies, I missed the part where the pad recommendation was given. There are a few in here that got tossed into the mix.
Is it the LC green or white pad that should be utilized for an AIO? I'm interested in utilizing McKee's 360 as my AIO and am interested in knowing what pad would be best paired with my GG6?
I think someone else asked it earlier, but what LC foam pad is ideal for an AIO? There are multiple different LC foam pads. Which LC 'model' of the foam pad should be utilized? the CCS? the Hybrid? the Flat pads?
I have learned from experience than a one step is an improvement and not perfection.
I feel, generally speaking, that most people prefer glossy with some swirls and RIDS Over a dullish looking finish.
Exactly!!! Including interior as well! What are they smoking????????????I've had customers come in thinking a "detail" IS a Full Correction.
