Coatingsarecrack
- Dec 9, 2018
- 7,925
- 618
I don't see the issue with foaming twice. My line of thinking has always been to get as much dirt off the vehicle as possible before doing a contact wash. Plus you can always use an inexpensive soap such as Meguiar's Gold Class or Hyper Wash.
To an extent, I do agree that if someone foams and then goes straight to the contact wash, they are rubbing the dirt into the paint. In my opinion, a much safer method would be to rinse the foam off to remove most of the dirt and then either foam again followed by a bucket wash or go straight to a bucket wash without foaming again.
As far as using the pressure washer, would you rather rub dry dirt against your car or mud? I'm sure everyone would agree the answer is mud. For this reason, I would foam first (or at least soak the car with water using low pressure) to soften any dirt, then do a high pressure rinse.
Eldo’s main thing is Ivan says you should pre foam, rinse to remove dirt and that he says just using PW to rinse before foaming or washing can cause swirls.
Eldo asked him to prove it and his response is we don’t purposely damage cars…
