IOMCAMARO
Active member
- Oct 29, 2010
- 1,119
If you have some directions that state to use a medium-light cutting pad...then we have a problem. The instructions should say finishing pad.
It was in your directions Chris.
To apply Optimum Finish, use light to medium buffing pressure with a finishing foam pad (no cut). For high speed buffers, 1000-1400 RPM will provide excellent swirl removal and a flawless finish. The polish is aggressive enough to remove 2500 sand scratches, but fine enough to produce perfect results even with a high speed buffer. For orbital buffers, use a medium to light cutting pad with moderate speed (3-4) and pressure for desired results. Always use enough polish to create a barrier between the buffing pad and the paint surface. Wipe off residue by misting either water or Optimum Car Wax and gently wiping off with a plush microfiber towel.
