Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
In the grand scheme of things, there's no way you would be better off doing it by hand. Look at the positive side, you were able to remove the swirls and scratches, now all you have to do is figure out how to get rid of the marring, or at least minimize it. You'll figure it out, just like I have faith I will too. :dblthumb2:
And that's a good point.
It's important to remember where you started from, you've removed most of the major defects so now all you have to do is dial in a process to build-on the results you've already achieved.
To date, whenever I've run into any micro-marring problems on paint the Wolfgang Twins have always proven themselves to fix the problem.
Usually the Total Swirl Remover will finish down micro-marring free on soft paint, but if there is any micro-marring then the Finishing Glaze remove it.
White polishing pad for the TSR and a finishing pad for the Finishing Glaze.
Take heart... with the helps of the forum members here on Autogeek Online we'll see you through to sucess...
:xyxthumbs:
