So he had to make sure it did or he would not have gotten an invite from that visit. I haven’t watched his videos in a long time and not do I intend to.
Alaska uses salt but different than most places (I think), here they mix it into the enormous piles of dirt they prepare each year for sanding the roads
It keeps the piles of dirt from freezing into solid mounds of ice
Regardless we end up with salt on the road and over the last few years they have started spraying salt brine as well so we get hit pretty hard at times
I like anything that stays on the surface and dwells rather than running down immediately so yeah, I am prepared to embrace foaming
Look into the Frothe salt version. I like the original. Tricky at first to get spray pattern down at first but now it’s a breeze.
I would treat it like a pre treat in your case and then do a rinseless.
Is there anything about the AMMO foaming sprayer that other brands can't do?
$60 seems a bit steep
I just bought Larry’s basically for all the support you get from him.
When I called with an issue I got him. Not to many other influencers answering their phones with advice about their products.
That is a massive battery.![]()
Already ordered. Ordered direct so I could get the gray blower band.Get a stubby nozzle next.
Stubby nozzle showed up.![]()
Comet Black Pump Up Foamer $33 but have to pay freight. Just like Ammo though! I really like mine. Use 1 1/2 liters to finsh one car or SUV w/Bilt Hamber It does a great job slinging foam.
It may be a surprise but since getting mine, I haven’t washed a car to try it yet. But I’ve used it several times to blow leaves and it’s amazing. The battery does deplete quite fast when using all 765 CFM but for the amount of leaves I have, it was plenty for a few sessions. I’m sure it will be enough for drying a norma size car as well.
The difference I noticed with drying a car is that you hold it much closer to your head/ears when you're doing the top of the car. You're not gonna do that when blowing leaves. The noise was enough that I'd consider using some ear plugs next time. Either some corded earplugs I can keep handy or some high definition plugs I have that only give ~10db reduction.
I definitely will use ear protection. I haven’t used it on a car yet just because I haven’t washed one. Either no time or bad weather on days I could. My wife’s car definitely needs a wash. Mine is dusty and due for a wash later this week.
I have the same ones, they're great. I use them mowing the lawns and detailing as well. I also use them when walking the dogs, but with the noise cancelling feature turned off, so I have some situational awareness. They were a Chrissie present from Mum, about 4 years ago, and they're still going strong.
