Interesting new add to the RW market:
PRELUDIO ACIDIC - #LABOCOSMETICA - EN - NEW
Sent from my SM-F936U1 using Tapatalk
Most of us use the solution as a pre- WashInteresting new add to the RW market:
Most of us use the solution as a pre- Wash![]()
I had a very good user experience just using IdrosaveHoly cow, Preludio is here??
Maybe you missed it, but when Idrosave was introduced, Reggy from Labo was on a podcast, I think it was EC Details, and he stated that Idrosave was supposed to be part of a 3pH rinseless system, but the other two components were taking too long, so they decided to release the Idrosave by itself. He did say then or elsewhere that the pre-wash part was called Preludio, and that there would be an acidic and an alkaline version.
EDIT: It looks like the alkaline is out also, although these don't seem to actually be available yet: PRELUDIO ALKALINE - #LABOCOSMETICA - EN - NEW
Oh, and just to more fully explain, these would be like using Touchless or something like that, but not having to rinse off after, if you drill down in those above links, to the "how to use" part, it says to spray on, let dwell, then proceed with your rinseless or waterless wash. We'll have to see if the acidic and alkaline are supposed to be used sequentially, or separately.
PS It looks like the Labo USA site is getting ready for this, because they are adding some wording about Preludio to the Idrosave page, it shows up in a google search but not on the actual page.
So with the acidic and alkaline pieces aside, I'm just picturing the Adam's foam and rinseless multistep process here. The big complaint there was it was a mess (naturally given it was a pre-foam before rinseless).Holy cow, Preludio is here??
A 3-step rinseless seems to be over-engineering things here.
A quick read thru the blurb seemed to be more like a 2-step, they didn't seem to be saying use both the acid and alkaline, it seemed like one or the other depending on what you were trying to remove.
Just to play devil's advocate--is the 3pH conventional over-engineering?
Methinks you might be onto somethingThe true devil's advocate here is... isn't everything most of us do over-engineering?!![]()
This guy did a simple test and Absolute lacked in cleaning power.
https://www.youtube.com/watch?v=qUUFVtXleqY
A 3-step rinseless seems to be over-engineering things here. It'll be interesting to get some actual reviews since Idrosave has good/bad after so much hype died down.
This is Acidic. Will eat away at waterspots and other organic material. I’m thinking for winter and Fall cleanings
This would be like a rinseless version of a 3Ph decon wash. Thinking probably use 1-3 times a year.
I'm interested in this high pH RW, is it a foam though?
It will be interesting to see how Reggy suggests the use of the Preludios. I don't see any indication that this is going to be available in the US/North America anytime soon, other than that the Labo USA website did add "Idrosave is compatible with Preludio in both its alkaline and acidic versions." to the "alternative use" section of the Idrosave page.
