Those swirl marks that he has are shallow and light.This is caused by micro dirt in the mitt with to much pressure applied.
Nothing noticable, but corrected just to be sure prior to coating. I've never used coating so I went with McKees. I think I applied it correctly.
Not sure what this is, sorry.
When washing I typically make a pass at the top of the panel working may way down. After making 3-4 passes, I flip the mit over and wash that same area again. Then I rinse the mit and start the process again. For example: 3-4 passes only covers the glass, rinse mit; then the door to the trim.
In that case, I would recommend a good HEAVY rinsing before ever touching the car, heavy suds in the clean bucket, a rinse bucket AND an intensive blast with the hose to the mitt after EVERY pass, no more multiple passes and "flipping" the mitt. And more frequent rinsing while doing the wash so dislodged dirt is washed OFF the car instead of being allowed to get stuck back on the surface if the soapy water dries before being rinsed off.
I'm against tunnel washing as well it makes life easier sometimes.If you find the right tunnel wash that is clean and pretty new and less abrading cloths there not that bad.90 percent of scratching and marring comes from the prep guys slamming there wash brooms against the paint.
Well, here is a fact and this was told to me by someone in the automotive paint industry. With the NEWER high end GM black vehicles, they're is using a softer clear on BLACK paint. You have very soft paint and just being black, you will see everything. I don't care how good you take care of ANY black vehicle, you're gonna see noticeable defects, especially on newer GM black paint. Either deal with it, or buy another color. Seriously.
Why would they do that? The only reason I can think of, and I guess this might make sense to a dealer, is that when people come in with their swirled-up black car, it's easier for them to polish out.
Quote of the thread!!!I think the saying goes: You don't own a black car, a black car owns you.
Up until my current car, every car I've ever owned has been black. I said to myself that I would never buy another black one again when I was getting my new one. Just way to much work and aggravation.
Not sure where to go with this as frustration has hit. I was fortunate to be able to purchase a 2016 Yukon Denali back in May. I broke one of my own rules by picking black as a DD. I convinced myself that I could deal with it, but it is making me crazy.
Could be products, could be technique. No slam at all intended as I'm sure like all of us you are careful and have good intentions. I do as well and can only really share what I do and use in hopes that it might shed light on some things compared to what you're doing. Just trying to help. Overall all the above sounds great. I'm not a two bucket guy when washing but that's me. I use two microfiber sponges and the same top/bottom technique. Instead of a rinse bucket I simply use the hose to blast off the sponge after each pass/section I wash. I use only the weight of the sponge as pressure with only a single pass over each area, never back and forth. I also wash front to back and dry or buff in the opposite directions only as to fully see if any scratches or marks appear which process is causing them. IN my case I've found every single time that I see a mark or imperfection that it's in my drying or buffing strokes.
I air dry 95% off my car and never wipe with a dry towel, always one that has been wet and squeezed out to the point where it's wet but won't leave streaks. I wet it in a 1gal pale that I fill part way with Uber Rinseless or CarPro Echo combo'd or simliar and distilled water. Wet the towel, wring out and go.
Wash wise, I am 90% Rinseless with a modified version of Gary Deal. 10% I may use a bucket. Even in harsh winter crap. I personally find the technique very safe and honestly a lot quicker overall and less messy. Lastly, I focus more too so while it sounds odd that I can focus and be more precise yet finish faster, I think it because there are less steps and less prep/clean up. I would as I did read, correct the front three panels and start over. Hood and two front fenders.
Happy to chime in again, but hope the above gets you a start or some information that's helpful. Hang in there.
