BF HydroSeal is Spray on/rinse off after a car wash/rinse and before drying). BF SiO2 Spray a more traditional spray on, wipe off spray “wax”. BF Coating Booster does seem a bit redundant to SiO2 Spray, but is less substantial and not really strong enough to be used standalone in my opinion. Consider it a watered down, less polymer’d version of BF SiO2 Spray. It’s OK when only topping coated surfaces though.Can someone explain the difference in this vs bf hydroseal? Or the bf hydroseal concentrate?
Actually, let's go 1 step further, how about bf coating booster?
I'm looking for an si02 regimen for my toy hauler. But it seems as all the house brands have a slew of overlapping products.
So what the difference in the 32oz hydroseal and the hydroseal concentrate. I mix myself and end up with more product for a lower cost?BF HydroSeal is Spray on/rinse off after a car wash/rinse and before drying). BF SiO2 Spray a more traditional spray on, wipe off spray “wax”. BF Coating Booster does seem a bit redundant to SiO2 Spray, but is less substantial and not really strong enough to be used standalone in my opinion. Consider it a watered down, less polymer’d version of BF SiO2 Spray. It’s OK when only topping coated surfaces though.
Sent from my SM-N950U using Tapatalk
So in your professional opinion. Hydroseal concentrate is the best option to go fornin terms of length of protection and ease of use in the rv situation?Blackfire SiO2 Spray Sealant - This is a stand-alone SiO2 "Silica" Spray Sealant. If you want to use it as a stand-alone sealant I would recommend prepping the paint surface first, so it can bond properly to the paint surface. This should be applied to a clean, dry, cool to the touch paint surface. It can also be used to maintain the hydrophobic properties and add slickness to ceramic coatings. A lot of ceramic coatings have a "Rubbery" feeling to them and most customers want the "Slick" feeling. This SiO2 Spray Sealant is extremely slick an a little goes a long way.
32oz Bottle - Retail $47.99
Blackfire HydroSeal - This is a "Ready-To-Use" SiO2 Sealant that gets applied to a wet surface. After you're done washing your vehicle, simply wet the surface and spray the HydroSeal and immediately rinse the surface with a strong jet of water. Start at the top of your vehicle and work your way around the vehicle working on one panel at a time. Make sure the surface is cool to the touch and work in a shaded area. IMO this product is perfect for large Trucks, SUV's, RV's and Trailers.
32oz. Bottle - Retail $45.99
Blackfire HydroSeal Concentrate - This is the same product as HydroSeal, but in a concentrate version. Perfect for professional detailers and offers a better price point. Your average consumer likes "RTU" products, but a lot of detailers prefer concentrates. The 1:7 dilution ratio will produce 32oz. of "RTU" product with the small 4oz. bottle.
4oz. - Retail $21.99
8oz. - Retail $34.99
Blackfire Coating Booster - This is simply a "Booster" maintenance product for any ceramic, quartz, or resin-based coating. This product will add slickness and shine, as well as hydrophobic properties. It's not as durable as the SiO2 Spray Sealant.
32oz. Bottle - Retail $29.99
I've used it on every exterior part with no issuesIs this product ok to use on the headlights/taillights?
THANKS..
THANKS..
Mother's 1, Mother's #2
Yes the AIO will replace the 1&2 in the future. Was VERY impressed with it on the Range Rover.
Sounds like I should not use the Blackfire AIO prior to Blackfire Si02 sealant because it has a protection layer? I am entering 2020 with decreasing reluctance!
Halve a half button of 1&2 left, so want to know about the AIO when they are goneView attachment 68340
BTW, for years the #2 was swirl remover/glaze. Did a great job removing the semi annual carwash/life marks from 6 months
