DFB
- Aug 12, 2019
- 4,890
- 2,959
- Thread starter
- #1,021
Friday Tinkering..................
While I wait for the replacement dust shields, which were supposed to turn up this morning, I pressed on tying up a few loose ends.
First, I decided to swap out the K&N air filter for a new one. I've had one in this car from very early on, having a second one allows me to swap it for a clean and dry filter straight away rather than having to wait for it to dry before re-oiling. An extravagance I suppose, one that somewhat negates the point of having a re-usable filter and supports the idea of just using throw-away OEM filters. But then I wouldn't benefit from the extra 40hp the K&N brings to the table....................:laughing:
For the record, early on I tried removing the intake restrictor but immediately put it back in. At the time I remember searching for information on this apparent "free mod" only for me to discover what I felt was actually true.
That intake insert was intended to increase air velocity, in the process bolstering low-end torque and further tuning intake sound quality. So, while it has the potential to deliver more air to the engine and increase the volume of the induction note, the benefits are only felt at the top end of the rev range, while also delivering less favorable resonance. If you were racing the car, fine, take it out. But driving the car as it was intended, with the occasion run to the red line, leave it in.
This is a more technical description of what's happening I found on another forum -
"......more velocity = better atomization = better mixture distribution in the combustion chamber = better combustion = better volumetric efficiency......"
Strangely, there doesn't seem to be much imagery online about this part of the car. I lifted these shots from the video I'll post below -
Next, onto something only the truly deranged would do............de-nibbing the tyres on the XR6.
A completely absurd exercise and one I even question the point of, but for some reason, tyres look better with them removed.
After adding some additional rubber lining to one of my cabinets, I decided to tackle the deteriorated primer bulb on my Victa MasterCut.
While this wasn't leaking, the rubber bulb had started to perish. The bulb is not replaceable on its own, so the whole cap must be swapped for a new one. Because I had two in stock, I thought this would be an easy fix.................
But no, after replacing the primer cap with a new rubber o-ring, I turned the fuel tap back on and ended up with fuel pouring out of the primer bulb. I removed and re-seated the cap to the same result. I then removed it again and replaced the float needle and put it back together again. Same thing happened. I then pulled it back apart and discovered the OEM float was not pivoting freely on this aftermarket primer cap. So, after cleaning the original cap and re-installed with the new o-ring, the problem stopped.
Clearly the aftermarket primer cap doesn't play well with the OE float. I'll order a couple of aftermarket floats and an updated primer cap that comes with a metal, rubber tipped needle which is supposed to prevent chamber flooding.
https://www.ebay.com.au/itm/264209167805?hash=item3d8417f5bd:g:BVsAAOSwoPVkPoW 1
So, that was a wasted 30 minutes, only to have to do it all again when the parts arrive. :doh: I'll just write it off as a learning experience.
