O.C.Detailing
- Jul 24, 2009
- 740
Eric is making pads with the velcro loop to the edge, and we'll have to see if that solves both the loop separation issue AND the tearing/cutting issue or at least the tearing/cutting issue.
Have you had some pad issues as well Trichard? What were your experiences with them if you have?
This a great thread for sure and the Hydro pads do work great. It does seem that some are using way too much pressure and causing themselves misery. Also sometimes it does take more than two days to dry these pads, I would suggest setting your wet pads on sweater dryer so the air can circulate through the pad itself.
I've seen times where I tried using a pad that felt dry, but immediately after my 1st pass, I knew there was moisture still trapped within the pad. It will affect the level of correction, gum up the pad and created problems for the pad itself.
If you want to use the same pad again on the same detail, you better just clean it on the fly with a brush/air/towel and keep on trucking. Once you introduce water to these, sit it aside to dry for a while (at least 24 hours).So David, I'm guessing that you don't use any type of pad washer like the Grit Guard or Autogeek? No way you can use that pad washer and continue to use the pad right?
I agree 100%. Take a look at post #96, that's one of my 3 pads that failed the exact same way. It's not the velcro delaminating, it's the foam tearing. This doesn't have anything to do with a wet pad, although I always let the pads thoroughly dry. My CCS pads hold up very well, and I use the same technique. Once the velcro loop is moved to the edge, the problem will be solved, I'll put my whole bank account on this(nothing..lol). For those who have not had any problems as of yet, either you baby the pads, or you haven't used them enough.Anyway, as I've previously stated, waiting DAYS for a pad to dry before you can use it again is totally unreasonable, so there is an inherent FLAW in the design that needs to be addressed by the manufacturer and it is.
