Kristopher1129
- Jan 3, 2011
- 2,861
- Thread starter
- #41
Well, here's another update just in case anyone still cares, haha.
The good news: The break lines were leaking only cause they needed to be bled, not replaced. That's the only break I've gotten on this van so far, ha.
The bad news: When I took it to the mechanic to get inspected...he found rot on the front end chassis. Didn't wanna hear that at ALL at this point in the build. Basically, the chassis holding the radiator in place, was detached from the sub frame due to rust rotting out around the plate connecting to the frame and the bushings. That probably makes no sense...but that's how I understood it.
So, the whole entire front end had to be disassembled to even reach the spot for repair. Luckily the plate, and the bushings were still strongly connected to the frame. So we just had to reconnect the chassis to the plate with new steel welds. So that's what we did. How much did it cost me? Zero! That's the good part of the bad news, haha.
My Pepere is a mechanic, and my girlfriends dad is a welder. Problem solved. So, it's back at the mechanic right now waiting to hopefully pass inspection with flying colors tomorrow. Wish me luck. If it doesn't pass...I'm blowing it up.
