Andr3wilson
- May 16, 2012
- 1,615
Looks good with the flashlight app.
:xyxthumbs:
I would try 205 or UP on a mf finishing disc. That also worked for me
Sent from my Galaxy Nexus using AG Online
you might find SF 4500 doesnt have enough cut for the swirls...
if thats the case, and you like the Menz, you might want to try SF4000. it has more cut, but finishes almost as nice as the 4500 on everything but black. On your tundra you will likely need to finish with the 4500, but it will be worth it.
Menzerna, Menzerna Polishing Compounds Products, Menzerna FMJ, menzerna polishes, menzerna car polish, menzerna nano polish, menzerna final polish,
why would he have to finish with 4500 if he uses 4000? I thought they had same gloss level (5) but more cut with 4000.
you are correct...according to the chart, they do have the same gloss level and should finish the same, but if using it on soft paint like th OP believes he has, the 4500 will likely finish better because it has virtually no cut...more of a pure polish...and it will bring about the best finish possible IMHO.
it was merely a suggestion that if he tried the 4000 to hit the swirls, that it might look better with a polish of 4500, but IME it will finish it much better.
